cimaguy
Hello
I have just started using alphacam (version 2017).I would like to know if it is possible, in the 3d finish but also in general, to define the surfaces of "check" i.e., in order that the tool works, for example, a horizontal plane but is at a certain offset from the vertical walls, so as not to heel. Thank you.
