info together welded
  • Thread starter Thread starter windreef
windreef
Hello
the welded axieme, as a distinct setting, must be necessarily "inseparable". in the sense if I impose it as "normal", like any set, what problems can it bring?
I ask you this because to have a separate cut (with inv2010) I open the main axieme then go on separate components (only parts) and carry out the data that I need, but I noticed that in the welded assemblies does not take into account the pieces from which the welded is composed. However, setting the first value on "normal" the problem is solved. But I don't know if I'm going to deal with future problems, on the other hand if they set it up like that, there's a reason. or perhaps not:confused:.
Hello everyone
the only thing that changes is, in fact, the way in which it is managed in the distinct components, "inseparable" does not appear the sub-components of the welded axieme in the distinct... if it's better with "normal" for your needs, use it quietly
Okay.
Thank you very much
