information about parts to develop
  • Thread starter Thread starter Fere
Fere
I was wondering and I'm going to some expert on the question: with inventor is possible in standard environment part obtain the development of a particular calandrate?
I make an example:
If I echo with the leadership revolution a profile of upn (so fallen) can I get from inventor its development?
If you like?
otherwise how can I proceed?
Is it possible to do something like that?
other question.
in sheet metal environment can I create a sheet metal or a cone and then get its development?
Thank you all.
to make the simple development of an upn calandrato nn serves inventor, do much earlier with a simple calculator.
In the sheet metal environment, you will surely develop cones and sheets, but the same is a simple sheet, first with the calculator, if it is a sheet with different holes, or with a shape to mate a tube, inventor you need.
In fact, I have to make a 1100 full-grained sheet.
How can I make it?
In addition, with regard to your answer on the upn, I agree with you that with a calculator I do first, but I wanted to know if inventor is able to do such a thing and how to proceed.
you create your upn with content center, then there is the appropriate command "full part" where you will give the bending radius (command already present from version 2008)
to make the sheet metal you can create a flat sheet, do all your holes, then use the fold part command, always giving your fold radius or create your pipe (open not closed.
with the 2010 , you can alternatively create your sheet with the diameter you are interested in, then use the "distendi" command in order to get the sheet in paino, do all the holes to measure that you are interested in, and then "recover the sheet".
Thank you all.
I have inventor 11. with this version is there a way to spread the sheet once folded?
I make an example:
If you like?
other question.
Thank you all.
eye to the development of a unp calandrato profile.
theoretical development will be different from the real one for a series of factors:
In fact, if you are dizzying with external lips, or inside, or calandrated on the side, the material reacts differently that maybe depends on the quality of working in the foundry or other factors unknown to us (and to inventor).
so if you have to send a development in the workshop, insert in the drawing of the notes on it.
Then, if it can be useful with regard to the general rolling, there is also this post:http://www.cad3d.it/forum1/showthread.php?t=11947&highlight=calandratura&page=4
