information about sifting
  • Thread starter Thread starter Joshua662
Joshua662
Hi guys is so much that I don't write on the forum, today I really need you because I have a problem that I can't get a solution, I'll tell you better:
I have a sheet thickness 1.5mm that goes connected to another lamera with the same thickness through thread insert m4, my problem is the following I would put the head of the screw an iso 7046 m4 but with the procedure hole of cat v5 the head of the life always comes out the lamiara, I performed this procedure, I claculated the 3/4 of the thickness and nothing, I did the hole instead of dn0°. Who can help me? thanks to all those who will respond.
