information about the properties of a solid to be inserted in a table
jim78b
Hello, I would like to know from programmers if I can from a solid table a data field that tells me the height of extrusion and maybe other dimensions, so if I change it in table
The fields available for solid entities are tight enough and nothing that can do for you.
via lisp, it becomes impossible to get the value you sought (the list of entities of a solid is a very strange thing)
I don't know if visuallisp is less ostic, but still data field automation wouldn't get it.
understood I can only put as data field a quota that falling the solid changes and therefore also in table
more than anything you can quote the solid vertically (ruoting theucs) and having activated the membership fee option.
Once back to the normal ucs, ironing the solid, automatically pulls behind the quota.
I don't think there's a field that gives you value of the quota (a field intended as a field to be inserted in a table)
