fpaolelli
hello to all, I know quite well autocad in drawing 2d now however for necessity I have to enter the world 3d but some gaps make me complicated the work I put you so maybe you could help me.
is creating a scaffolding in three dimensions starting from the individual components developed according to 2d designs.
first question the correct positioning of the elements in the mule case of the bushings that must be placed at precise distance in the center of the mountaineer, how would you do?
second question as the design enlarges I would be comfortable to combine the individual parts of the elements that the body the head the bolt of the current in the only current element without having to each move select the elements, in the 2d I used the blocks can be done also in 3d?
Thank you and excuse the peeling. !
