informazioni sw
  • Thread starter Thread starter Smoke87
Smoke87
hi to everyone, this is my second post, I hope not to create too much trouble, I worked until a month ago with inventor I used for 5 years I have been in the past in a company with sw base, I find myself a little distracted, I wanted to ask a lot of things, the point-by-point list, I don't want to look too prolixed or to be tacked like puzzles. . .
- I find it difficult to quote, I must always put the view with hidden elements visible for not having boredom, is it normal?
- I put the single component on the table, but when I put the quantities, I'm going to put them by hand, it doesn't take them together.
- possibility of autodrawing various components starting from the axieme? (obviously then boards and quotas arranged. )
- change list of slots (usually I follow the number part and connect it to the number of position es d001 pos 1,
for now I will throw you these 4 ideas.. recommended pdm use? and maybe upgrade license? How much does it change?
Thank you very much in atipe.
hi, pdm sure helps, however, depends on how many you are in the office, the type and quantity of the components produced as well as the desire to invest money from the employer, then it is also up to you to direct it if you used one previously... .
for the rest maybe if you can put some pictures, I don't understand the questions.. .
bho... If you don't write that boredom has how to respond?
What does that mean? that you make the table of the detail and want that on the design of the detail write how many times it was used in a x set? if this is not possible if not with macro or escamotage (already treated in the forum); Moreover as the same part can be used on multiple assemblies in what way solidworks should understand what quantity to insert?
What is the autodrawing? would you want me to crush a solidworks button automatically make a constructive design by putting the three primary views and random odds or drawn from the model and then take every single design back in your hand, losing time to re-set everything? you only do it with a macro
I don't remember this, but it should be possible
No, it's not normal. It is a condition that occurs very rarely and only on welded (multibody). did you activate the "dynamic highlighting from graphic view" option in display options?
It seems normal if you do not use a tool that goes to detect the quantities in the axieme. I quantity the "marks" with the pdm during printing or exporting drawing files. It is an information that must be written on the flight and not saved, because the same component could be used in other axioms with different quantities.
to me does the pdm to the creation of the code. I think it's a little influential in productivity. . rather it is advisable to "recycle" similar tables, making a copy and replacing the model inside.
There is no way to handle it automatically, but if you want to reorder a separate one just drag the lines.
