ingrandire anteprima in draftsight18 o esplora risorse
reggio
ciao, perdonate questo mezzo cross-post (https://www.cad3d.it/forum1/threads...-autocad-o-esplora-risorse.52669/#post-412766)
I happen very often to use the draftsight preview 2018 or the preview of explores resources to look for one or more drawings in the middle of many others, the problem that I find is that both these previews are sometimes too small to allow me to recognize a drawing from another.
also the expedient to set "very large icons" in explores resources, which works egregiously with the images, with the dwg fails miserably ...
I was therefore wondering if there was an alternative solution, maybe a free plug-in or other diavoleria that allows me to recognize the designs without having to open them all.
... as you will see in the same post dedicated to autocad, it is possible but with a version greater than my 2011 so I did not solve,
I tried the same autocad command "thumbsize" on draftsight 2018 but df does not recognize the command...
sin because in sw it is possible to maximize the preview window as if it were an image, and this gave me hope, but it only works for parts and assemblies: with dwg/dxf does not work, they remain small and not recognizable ...
question: Do you have experience with draftsight 2018 and know if and how it is possible to enlarge the preview window?
