inserire given its part in lamiera
  • Thread starter Thread starter pasquale83
pasquale83
Maybe I'm about to say a ca--ata...
I have a part in sheet (to fold), on which a nut should be soldered
how can I do to insert the dice from the toolbox in the part, without creating a set?
I tried dragging the nut from the tb, but it doesn't make me choose the size, as it happens in the assemblies, why!? :confused:
or draw or insert part and position with the couplings of a set.
the advantages of the first is the speed of execution
the advantages of the second is the possibility to take advantage of the configurations and then change with a click the size and have an element already prepared for the cutting distinction
pasquale83, it is good education to thank and give feedback to the advice you are given. We are not working for you, indeed we are not working at all! ! !
the forum:-It is not a place where a question arises (maybe even insisting) and once you get the answer you no longer feel, without even saying thank you. thank you is a form of respect and gratitude.
- It's not a place of robbery, where I just need to go and then I disappear until the need arises.
the above phrases are drawn from This is post
I apologize if I seemed rude and/or anything, but I simply read the messages in response, but I did not have time to carry out the tests, so I "frozen" the question, but I would have responded as soon as possible, as I did in other discussions;)
il forum:-It is not a place where a question arises (maybe even insisting) and once you get the answer you no longer feel, without even saying thank you. thank you is a form of respect and gratitude.
Unfortunately as I have already said a long time ago, I would like to actively contribute to the forum, but normally the questions are above my knowledge
to return to the topic, to pass quickly beyond, I inserted the dice together so as to have the voice in distinct base(that I still have to prepare)
the contribution is not only to give advice or to intervene in addressing a problem, but it is also to report the solutions adopted to solve their problem; who are following the advice received or adopting a different method. so who in the future will read the thread will have information on which to reason.
of menefreghista people and parasite there is not too much in the forum. and since I'm breaking the Zebedei every now and then I shoot the message you brought to try to wake up to consciences
stop polemic
if you insert the nut into the part you can have the voice in the distinct materials. the solution, together or part, depends only on the type of distinction you have to use
