Thank you, that's exactly what I was looking for. would be possible, having multiple squares formed by polylines insert an incremental numerical text (1, 2, 3, ...)? Thank you again.
always larger, and I prosecute what I was trying to do, the only problem and that I have blocks constituted from a square (polyline) and text so I have to use explosions to run the macro, the blocks would be numbered from right to left and from above on, launching the macro numbering happens randomly, selecting each single block respecting the desired order and then proceeding to correct numbering
the thing is making me unpack, perhaps it would be better a macro that selected the block manually proceeds to the creation of the label with the counter.
Thank you very much.
launches the macro autotextrect, the texts write them by referring to the insertion point of the blocks, then you will find them moved very far to the left, in your case.
n.b.: if the previous routine you think can serve, rename the file because it replaces the previous one.
I tried to launch the macro but it doesn't give me any results, it goes running but no writing appears, what can I do?
Thank you for all the time you're dedicating.
make an extended zoom, the lyrics find them quite moved to the left.
This is due to the fact that the point of insertion of the block is not coincident with some summit of the entities that compose it.
I'll train your completed dwg.
perfect, I didn't see the text on the left but just what I needed. If I can still read a little bit of your patience the text I have to insert and compose: s 0001, s 0002, s 0003, ..... etc. the problem and that putting the numbers are of a magnitude 0.5 the "s" and of a different size 0.7 I tried everything but I can not assign greatness to a single text.
before starting the macro, set text style and height.
the highlighted part you can change it to your liking to set the text height that contains the numbers.
0.70 means that the height you set, for example 2, multiplied 0.70 by 1.40, so you get the s by 2 and the numbers by 1.40.
