insert bmp images in file with desinenza exp
  • Thread starter Thread starter atesfa
atesfa
hello to everyone who will give me useful to my research and also thanks to the supermoderator who will evaluate if I am ot and will marry me where my thread is more appropriate.
problem: I have to insert in a pc of bpm images through a software that manages them on a visual terminal, the software gives me the possibility to acquire them with a certain resolution then launching the key importing the scan curtain provides me only the withdrawal from the peripherals of files with exp desinenza.
looking on the network I thought I understood that they are libraries that can contain mixed data and images.
I am looking for software that allows me to create a file with this desinence so that I can insert my photos.il s.o is an old 98 that I cannot update.
I'll be delayed, but I didn't understand a thing. Who cares what?? ?
kindly attach some view of the problem, and specific with the maximum precision names, surnames and addresses of the programs you are using, thank you.
first phase.I have to insert images into a determined resolution of pixels in a pc that through software turns them on a screen of advertising.
the software is a video library management, which also allows you to insert them with an external file and not only by connecting to the main server of the software provider to which I should pay a subscription, to download the images.
second loading phase in a jpg image file and in the other bmp as in the specification that opens to the pressure of the import key tells me that the images must have to tot resolution and bpm format. launch the acquisition and opens the file choice menu.but the basic search only allows to capture files with desinenza exp.qualcuno advised me to put in the jpg image files in 8 bit format. to you.
