frk
I realized, with the precious help of gp, that I thank again, this lisp.
starts with "cd"
attention to the indications at the beginning.
is very dependent on the used quota style.
starts with "cd"
Code:
; | lisp to insert on all the vertices of a polylinea coordinate quota |
; | (ordered in uk) x and y with base point (ucs 0.0) to be defined |
; | note: the coordinates will depend on the current quota style in the dwg |
; | values are always and only positive: act on the q style. x negatives |
(defunc c:cd (/ ent idx pts totparam p1 pttt pttx ptty)
(command "_ucs" "_w")
(command "_point" breaks)
(setq p1 (getvar "lastpoint")
(command "_ucs" p1)
(vl-load-com)
(if (setq ss) ((0 .*poly*)))))
(progn)
(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
(setq idx)
(while (< (setq idx (1+ idx))(ssslength ss))
(setq ent (ssname ss idx))
(setq totparam (fix))
(Sectq i)
(while (< (setq i (1+ i)) totparam)
(setq pt (vlax-curve-getpointatparam ent i))
(setq ptt (- (car pt) (car p1)) (- (cadr p1)))
(setq kk 30) ;write here the shift of the second point of the ordered quota in x and y
;the same value to be inserted in the quote style -lines and arrows- -offset from the origin-
(setq pttx (+ kkk (car ptt)))
(setq ptty (+ kkk))
(command "_dimordinate" ptt ".yz" ptt pttx)
(command "_dimordinate" ptt ".xz" pttty)
(setq pt (vlax-curve-getpointatparam ent)
(setq ptty (+ kkk))
(vla-endundomark (vla-get-activedocument))
(princ)
