insert in the same table orthogonal projections and assonometry
  • Thread starter Thread starter El_Torito
El_Torito
hi guys are a newbie using autocad 2018, I need a straight, can you insert in the same table both the orthogonal projections and the asonometry? How do you do it?
Thank you
the normal views and also the 3d but I would like to put them together in a table
If you can make normal views and 3d views what's not coming back?
I mean this.
apart from that I put you two links to the problem, I ask you better: do you do the standard views in the layout?
But if you have to go interviews bringing the toui drawings these must be bombing, it is not enough to put a three-dimensional view.
that design is quoted bad and therefore it is not a good business card.
try to attach the images made using the tools of the pc (gimp, paint or other) because made with the mobile phone are difficult to understand
So much to say, I the first question that I would ask you is: how do you revenues in reality that piece? fusion? Fresa? fold? Welding?
If you don't know how to use autocad, if you don't know how to quote, I think you'd better avoid drawings to the epic risk talks. not only during the interview, but especially in case it is assumed and cannot maintain the expected dates with your prepared drawings
I agree with you max, in fact now my goal is to get something decent in order to be able to face a possible interview thanks to the Straight
