insert new shapes in sketcher palette
  • Thread starter Thread starter Delysid
Delysid
Good morning, everyone!
If the debate has already been dealt with, I have looked quickly and it seems to me not.
as from topic I do not remember how to insert new objects in the sketcher palette... help me!
Thank you very much!
you must add in the config the following item:
sketchy_palette_path
and then you tell him the path, eventually you should have something like this
sketcher_palette_path s:\ptc\home\gd\stdgd\udf\sections
Thank you dema, I think I remember your name is config.pro? Right? and inside I put pro/e sketch files or parts?
the file is the config.pro or the config.sup but for this you should open a new discussion
However you go (I write commands in English)
tools tools
options
in the window that opens at the bottom left in the option box, type sketcher_palette_path and click on find opens a further window, click on the only option present at point 2, and the button below right browse becomes active the click and then choose the folder path that contains the sections already ready to add.
