insert radius of origin
  • Thread starter Thread starter citri
citri
Hello everyone
The title will probably be unclear about my request, but I wanted to ask you if you can tell me how to insert the source quota before a radius. I would practically have the need to cut some plates from our supplier who then have to be sent to work.
for the execution of the cut though, I should give the full length, you know how to tell me how to do it? I was able to do it back but quite casually and now I can't put it in.quotaraggio.webp
- share command
- click on the vertical line or at the bottom left (just on the image you posted)
- click on the diagonal line (he proposes the angle)
- before confirming right click and selections from the drop-down menu the item "intersection"
- click on the base line
Thank you so much to both!! !
I knew the solution of mauro but I wanted to avoid creating the sketch (although it is still a valid alternative), what I managed to do randomly once and that I couldn't repeat anymore, was just that of Ilario :finger:
ot
.....if you look at message n°6 of that discussion there was what you were looking for.
I write in the discussion that perhaps can be useful to all.. .
if you want to insert a link of a specific msg and not the whole discussion just go to the number of message (for example #6) right click and choose "copy address"
p.s. here is a example
