insert sketches part in the table.
  • Thread starter Thread starter Per5
Per5
Good morning to all,
I would have the need to insert certain sketches, so not all, but only those that I have the necessity that they appear, like the guidelines for the position of angles or calandrate dishes, created in the part, in the table of solidworks.
Thank you in advance that you can give me information about it.
I have the version 2016 and simply having the sketch activated in the environment part, whether used "for construction" or not appear without problems at the table. Immagine.webpin case you do not appear test with "restore the visibility of the sketch" pressing in the environment drawing button dx on the view that interests you
hello thank you for the quick answer you gave me, effectively with restores visibility of the sketch now I can see the sketch I ran on the part.
is the only way to view selected sketches from part 3d is to keep them or not visible in this?
it is not possible to set sketches so that they are the only visible, despite in the 3d part they were set as hidden.
you can hide them in the environment part/axis, they will remain visible until another "restores the visibility of the sketch"
in case you have, as you said, need to put only a few:
- part: hide those you don't need
- drawing: restores the visibility of the sketch
- part: hide others if they bother you or don't want them.
edit: the thing I don't know actually is if after saving the whole, open the files and rebuilt, the lines are still visible in the drawing
in the part you hide them while in the drawing you impose them for every view as you prefer. expand the view, go on the sketch and impose the visibility status
excuse the double post but for notification
I checked. Andy. and remain visible
edit: I had not seen the answer of mass d:
I am always referring to this debate, even if it treats perhaps another subject of the table.
when performing a view or section you can choose the display status that can be that of the father view or , shaded edges and removal hidden lines and others.
you can choose hidden lines visible and make sure that some parts within these views we removed them?
No. you do the opposite, you view without hidden lines and clicking on the set component shows hidden edges
