inserting windows with shields
  • Thread starter Thread starter luca67
luca67
Hello. .
I have been working recently with revit 2010 - I found myself having to realize a type of window (not present in the revit families) with dark.
I took an existing window as a basis and made some changes.
(dimensions, materials etc.) and then I imported into my revit project
I need some impunity (I'm stuck!!!!) :
- Why don't I see the frames of the dark ones in the design?
- How can I remove lines (probably building) from the prospects?
- I can change the type of "color" of a material to make a rendering
(I need a dark wood color but after many tests I couldn't get a dark brown! )
allego view prospectus and view 3d
Thank you in advance.
try to increase the degree of detail of the view
open the family and gates
manage>materials select the material and in the graphics tab click on the button that identifies the color and changes it
operations already tried .... but unfortunately without result....
I'm probably wrong in something!
now cmq with pazieza try again.......
cmq thanks
