patrizio
I have problems with the ug license in my pc. unigraphics I can install it correctly, but I don't read the license.
How can I do that?
Thank you in advance.
How can I do that?
ugii_lic_ense_file does not exist as a flex variable.the license file "ugnx3" I entered it in: c:\windows\temp
when I try to launch the program gives me the following error:
initialization error -
nx flexlm:the license server has not been started yet, or ugii_lic_ense_file is set to the wrong port@host. [-15]If I try to start.. programs.. nx 3.0.. flex lm.. license options gives me the following error
ugflexlm_options
unable to attach to server (-15) check ugii_license_file
in the license file there should be a line where it says:the license file "ugnx3" I entered it in: c:\windows\temp
ugflexlm_options
Could you please give me the path to the name of the pc.give me the path to trace the name of the pc. thanks
start/executegive me the path to trace the name of the pc. thanks
... to me the dos window appears blue.start/execute
type:
cmd
sending
in the black dos window, type:
set of computers
and sending
aftergive me the path to trace the name of the pc. thanks
