installation and settling micrsostation v8
  • Thread starter Thread starter mamu2005@libero.it
mamu2005@libero.it
good day my name is maximum, it is the first time I enrolled in a forum and participate in a discussion of this type on a site, ... we will see hope to understand the operation of everything etc...
However we say that I do interior decor and architecture more in general... I find myself having to reuse at a distance of a few years microstation triforma v8, I ask if someone can kindly help me understand some things , in fact I don't work the commands as should for example if I try to insert a free form with the place free form command, when I click with the dx to confirm it doesn't work disappear everything, same thing the command draws walls (place linear form). another problem I can't run the tentative button or at least I don't know how to set the central mouse button to make it work as a tempting selector, in fact from the button assignements menu I put: date on the left, tantative on the central and reset on the dx, but it continues not to work. . .
Meanwhile thanks to anyone who will want to intervene and hello
maximum
maximum
hello mamu, I try to help you as I can... Meanwhile I think the right button in microstation always cancels the commands (except for different personal settings) so try, to confirm, with the left mouse button.... for the attempt you are sure you have confirmed your change and then ctrl+f (removal of changes)? because the process to set it as right-click is how you do it...cmq to see if it is the setting or just the command that does not take you, the real tentative should be dx key and left of the mouse pressed at the same time. . .
hello and good pasqua
to set the central button instead of the two external presses together you should find a voice "assigning buttons" on the menus, then set attempt with central key.
with micro in English drop-down menu at the top
workspace > button assignements > you positions on the tentative voice then you move in the box below, the button definition area and clikki the keypad at the center (or the wheel).
confirmation with ok in the box at the top right
for the dx key is generally used as an undo, but you can change it with the procedure described above, as well as all other keys.
if change does not happen ...... Well, I think you've got a serious + problem.
However com micro v8 you have the osnap almost like in autocad, so if you pull a line and then you want to stick to one of the 2 edges he recognizes you automatically.
Just go over it and clik with the only left button, unless you have the osnap disabled.
