installation of mechanical bookcases comau lib 2002
domy1973
hello to everyone turning here and on cad3d I was looking for mechanical utilities to integrate to my 2004 autocad version.
I found the free utility comau lib 2002 I proceeded this way for installation
1) disappeared the file on the desktop creating the folder:
comaulib 20022) within the above folder are 14 files including the setup.exe file
3) I started the setup.exe file
4) the setup created me the following folder:
c:\programmes\comau\comau lib 2d
5) at the end of the setup I restarted the pc
6) start autocad 2004
7) I added point 4) path to sceda <percorso di="" file="" ricerca="" supporto=""></percorso> tools-->options
8) autocad lock
9) I reopen auocad but nothing happens, if I try to start the setcomaulibpath.exe program of that comau library I get a message that tells me that there is no autocad version on my pc, instead it is perfectly installed.
ps. Yet it is strange because in the installation phase of such libraries an informative message is issued that says it is compatible with autocd 2004.
Does anyone know how to solve the problem?? ? or if you can post the comaulib 2000 that seem to work well
removed the solution:
[Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep
installation utility free comau lib 2002
1) disappear the file on the desktop creating the folder: comaulib 2002
2) start setup.exe
3) the setup created me the following folder:
4) at the end of the setup restart the pc
5) start autocad 2004
6) tools-->options go to file tab and click on <percorso di="" file="" ricerca="" supporto=""> and add the following routes:
c:\programmes\comau\comau lib 2d\r15 ita
and then apply --> ok
7) tools-->menu click on browse until you find this file:
c:\programmes\comau\comau lib 2d\pop14win.mns
click on charge and then close the window
8) autocad lock
9) autocad reopens and everything works</percorso>
do you know if comaulib can also be installed on autocad 2009?
Cat
Yes, from the version of comaulib v9.0.00.
I am currently in version v9.2.07
Good morning, do you know if there's any news on comau libraries?
Does anyone know where to find all the bookstores in the various versions?
Thanks for any answers.
day to all, I would like to know how to install the comau 2d library on autocad 2014.gentiamente can you help me please?
Hello, can you help me find a compatible comau2d library on autocad2014? thank you.
