installation problems with autocad education
  • Thread starter Thread starter daho
daho
hello to all
yesterday I tried to download autocad from the student site. autodesk.com; before starting the site it made me download and install akamai netsession interface and then download started; once finished at some point the pc asks me:"choose the program to open the file 478dhf8u584hredfuru... which is the file of autocad" to which I do not know what to choose.
Does anyone know what I have to do?
davide
most likely you did not complete the download and that is just a "partial" file, not yet complete.
I downloaded the program with firefox instead of ie9 and with internet download manager instead of akamai, I ran it as administrator, I came to the window where you choose the destination folder , I chose it, I clicked install and began to extract the files; arrived at the file "extractingx86\acad\programfiles\root\locked\acad.exe crashed and after a few minutes a red writing appeared that said "cannot create x86\acad\programfiles\root\locked\acad.exe and csì for the following files.
What do you think happened?
davide
no space problems I do not have, use sp2 view.
I thought maybe they might be administrator permission issues, I’ve got the uac disabled and I don’t have passwords.I searched a bit on the internet and found this:
In view, if the user account control is active, administrators are also considered standard users for common operations. when you have to make changes to the system, uac asks for confirmation and, having it, "promotes" administrator for that operation.
advice: Put a password to the administrator account and use a standard account. to installs, if the setup.exe icon has a shield, the uac will ask you the password.
when you have to use an old program that must have full control of the hd,
right click on the executable icon - run as administrator,
because for a normal executable, for example an old program for win 98 that must save information in the folder "c:\program files", uac is not able to know that it must be executed as admin. note that this is necessary even if you are using an admin account.
Maybe this is it, you have any suggestions?
davide
Sorry but I don't understand what you mean by "where you're disappearing" , internet download manager downloaded it in the program folder of the downolads folder of the user folder, but I don't think it is compacted, if I click on the file or the file item doesn't tell me sompatta, it says open or run as administrator.Can you explain better?
Thanks again
davide
ah I understand,the folder practically set the program and is:
c:\autodesk\autocad_2011_italian_win_32bit
hi, Saturday I finally managed to install autocad but on my sister's nb.
Now I have to understand why I can't install it on my own, I think maybe the cause might be the convenient firewall that I didn't disable at the time of installation (my sister's nb doesn't have a firewall), or these updates that I can't install:
- Security update for microsoft .net framework 3.5 sp1 for windows xp, windows server 2003, windows view and windows server 2008 x86 (kb2416473)
a security problem has been identified which could allow a malicious user to damage windows-based systems running microsoft .net framework and gain access to data. installing this update provided by microsoft, you can protect your computer.
-microsoft .net framework 3.5 family update (kb959209) x86
This update is available for windows view service pack 2 and windows server 2008 service pack 2. microsoft .net framework 3.5 family update includes updates for compatibility for issues reported by users after the release of microsoft .net framework 3.5 sp1. This update comes under windows view license conditions and windows server 2008.
-protection update for sql server 2005 service pack 2 (kb970895)
in sql server 2005 service pack 2 has been identified a protection problem that could allow an intruder to compromise the system and take control of it. installing this update you can protect your computer.
for updates I sent the service request to the microsoft technician who advised me to restore the so .
according to you should restore the system (which I have never done) or download new versions of .net framework and sql?
Can these missing updates prevent the installation of cad and graphics programs (autocad, 3d studio etc.)?
is it possible to save the programs installed from the restoration?
How do you do that?
Daho
Disable the firewall and antivirus and try again.
those updates have nothing to do with your installation problem.
thanks for the advice, it came to mind also to me that maybe I had not disabled them.
regarding the firewall the microsoft technician advised me to uninstall convenient and put microsoft security essential, a free firewall of microsoft.
Can you tell me something?
Daho
... regarding the firewall the microsoft technician recommended me to uninstall convenient and put microsoft security essential, a free firewall of microsoft.
Daho
I never tried. I use alarm firewall zones that is also free.
However before changing firewalls see if the "responsible" is convenient.
I disabled avira and comfortable
I installed autocad2011(config.tipica),design review2011,material library,express tools,sp1.1,in the end it tells me config.completata,clicco on config.completata,clicco on install,but in the end when it starts installing visualc++ it blocks and appears unsuccessful installation.
the installz process log tells me installation aborted,result=1603
I don't really know what to do
some suggestions
Daho
