interactions abaqus
  • Thread starter Thread starter luchino
luchino
Hello, everyone. I contact you because I recently started using abaqus and I can't solve a problem. I must simulate a mechanical piece: a swinging beam to which a force is applied. so simple. the problem is that the beam is applied (as if welded) another indeformable material. what I can not do is the coupling between beams and indeformable piece. I think I have to work on the instances and interaction part. If anyone knows anything, can I answer? in case you have any example (that is not the tutorial) where you can understand this process?
Thank you so far.
