interoperability autocad revit
  • Thread starter Thread starter ocraM999
ocraM999
in revit the 'linked' file.dwg appears with all the layers on.
if you have changes to the autocad and embroidery file in revit, it updates everything except the on/off exit setting of layers. Therefore I must go <gestisci collegamenti=""> and correct the display.
in a few words, there is a way to connect a .dwg file as well as it was saved?
Mar</gestisci>
Mar</gestisci>
in the connection settings, above the measurement unit options, there is the layer option, default is set to all, if clickcli can choose as "visible" options
Thank you for highlighting the "visible" layer option, only that if I turn off a layer after connecting the dwg, in revit remains on. it seems that revit does not update the layers settings of the first import/connection.
From the point of view of interoperability it is very uncomfortable to intervene on the visibility of the layers whenever a design process requires it. if the layers are many you do first to erase the dwg and reimport it by afar. Or am I wrong with some passage?
Mar
