interpolation 3 axes
  • Thread starter Thread starter bizio_88
bizio_88
Good morning to all,
Does anyone have any idea how to insert the result of an interpolated milling along the axes x z and h?
I have the processing iso program
g0x7.z-0.5y3.t07
G98z1.1f150
g1x3.22z5.65h110.f300
G1x2.02z1.1h-110.f500
g1z-0.5f150
g0x7.
is a ø3 diameter cutter that is positioned at x2.02 to y2.55 then advances in z raising and turning the bar 110°.
Is there a way to replicate this processing in creo? ?
thanks to those who can help
with the little information you give, I'd say, going nose. .
models a round bar, build positioning and xyz work points, project a curve on the round, and then make a sweep, normal to the projection, which simulates the cut.
Did I guess?
or you have to give more info, type photo piece in work, type of work center and control used, scheme with axle name.
I don't have to do it with cad cam or anything, what I wrote is the program that works in the car, I just have to bring back in model 3d the work that does the brake.
Okay.
Build positioning and xyz work points, build a curve through the points, and then sweep, normal to the projection, which simulates the cut.
