intersection 3d
  • Thread starter Thread starter panormus
panormus
Hey, guys.
I can't understand why I can't find the intersection point between the sketch p plan and the combined curve c (see image).
Thank you in advance.
the message die error reports an update anomaly,
probably the curve you use is served to define the plane, so there is a father-son loop.
the combination originates from two skizzi on two vertical planes, the curve on which work is a sketch lying on a parallel offset at the horizontal plane, I do not find a connection between them.
tsdx on the element you want to know about the story, in the pop-up menu choose father/sons.
in the new window you can exemplify on the various elements the txdx and trace the feature historian.
I was born from your model that the curve combined comes from the sketch on which you want to do the intersection.
thank you ferretious, but how do you derive from any other sketch?
However thank you, as soon as I am at the pc I will see better;-)
The error is here
oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooeeeeeeeeeee
I solved by creating a zero offset plan, activating the sketcher and intersection. . found :finger: :biggrin:
...mh. and why don't you give me the bond of coincidence?
