intersection lines between floors
  • Thread starter Thread starter raffazz88
raffazz88
Hello.
Does anyone know how to display the intersection lines of the 3 reference plans (solidworks 2010)?! I have already set "show intersections" in the "view of plans" box in document properties....but lines remain hidden.
obviously you must have put the plan in the mode show.
Right-click on the floor and select show right; then in the menu view view put the check on Plans
I had already selected the "show" box in the plans.... but nothing to do...cmq thanks the same
I had already selected the "show" box in the plans....but nothing to do. .
But did you read what Massivonweizen wrote to you? :cool:
if not active also the display of the plans will be hard that you see them and see their intersections.
cmq thanks to the same
Please, you're welcome. By the way, at least what they wrote you earlier, then mike, did you read it? No?
I had also inserted the display of the plans....but it continues not to work....but what is this story of the presentation?! is the first time I use the forum...
.... is the first time I use the forum...
Right. then first of all you should read the rules and then at least "look around" before doing interventions.
..so to understand us:
see in the image that attached marcof the feature manager plans? if they are yellow are in mode show, otherwise they are, like defaut, hidden.
I wanted to say that I enrolled at the site in November....but only now I started using it and for this I did not read the mail....in any case I introduce myself: I am a former student of the second faculty of studies of napoli (mechanical engineering) and currently I am looking for work....now I am abroad to continue the studies (and possibly to find a decent job)...in this period I am attending a course of solidworks prime (60 As for my problem I have followed all your indications....but they were things I had already set....the dilemma so continues... thank you anyway to all
in the drawing tree you show on the 3 floors of origin, then in the menu displays active the plans (only this option shows you only the plans you create, so you need to put the exhibition even in the plans from the drawing tree).
thanks ivan but already I did....but nothing....in any case in that way you see the plans!!!and not the lines (tracked) that represent the intersections between the plans....
the display of the dashboard is related to the display of the plans.
Perhaps your plans do not intersect, did not doubt arise?
