intersection walls
  • Thread starter Thread starter frank28
frank28
Hello everyone,
It is a short time that I use archicad and I have a small problem with the intersection of the walls, a part of the wall intersecting seems to remain open, in the link there is the image that clarifies better. I would like to know if it is a problem due to some options or a bug. use archicad 15 updated to the last hotfix. Thank you all in advance for the answer.
it would be appropriate to see the construction lines of the walls (view> view and video options) and perhaps without the pillar that hides part of the design.
remember that archicad first collects the walls of greater thickness, then the others.
do so that the construction lines meet at one point (on the top edge for the horizontal walls, on the left edge for the vertical one)
