stevini
Hi, I have a problem with the intersection of archicad walls. 18. Drawing basic structural walls without any insulation layer or coating (change only the thickness of the wall) I have the problem that I can not often intersect and merge walls so that the line of the walls in the plant is a continuous line. It's like they didn't join, so they're separated from a line. as you can see in the screenshot between the two blue walls there is a line. Could you please help me?
