inventor 2011 - problems with 2d sketch
  • Thread starter Thread starter pagatti
pagatti
hello to all
on my pc with inv 2011 in 2d sketch mode I can not make the bows:
command line, click, egg mouse, click, create line. at this point if drag with left button pressed should make a bow...
on my pc this does not work, always makes another straight line.. .
Moreover, if I draw a broken one with various mouse clicks, then the extremes are not bound together...
on that of my colleague works very well, pcs are identical, maybe it only changes some update of windows xp..
also the applicationoptions.xml and usercustomization.xml files are the same for the two pcs....
Does anyone know anything about it?
hello to all
If you want to create bows when you are in the line command, you have to click the last point of the line, you can create bows and bind them later! for constraints you should activate (the automatically calculated constraints), from the sketch tab select constraint and activate constraint inference! if you want to disable the automatic calculation of the constraints activate the constraint persistence function! :finger:
You may also have all constraints as diegus said and while you create the sketch if you want to temporarily disable the persistence of constraints, hold down the ctrl key keyboard! try to create a line near a created object (a rectangle, another line), you will see a dotted line that facilitates the hooks (autotrak in autocad), at that moment you hold the ctrl and try to create a line, the dotted line is temporarily disabled!
