inventor 2024 does not take sketch references in the set
  • Thread starter Thread starter s.melotto
s.melotto
Good evening,
in a set I created a sketch to calculate the position of closed piston leverisms....
I would like to take a discrete point to bind the lever to the right point; I should bind the center of the red circle to the axis of the pipe of the pink piece.
I tried taking sketch point and pattern - tried to create an axis on the point to bind axis and pattern. . .
but does not take the sketch in any way!!!! I don't understand if it's an incorrect setting or if I'm wrong or if you can't just do it as I use a sketch element to bind my model into the axieme? ?
I don't understand why he doesn't. ! ! !
(same asm, I created an axis on a sketch belonging to a part of this together and, then, I bound created axis and geometry of the model together.... and it works; nnon understand xe in one case it does but in the other not)
sketches together do not allow to use geometries as an entity for constraints.
to do what you ask you have to have a part (fittizia) with inside the sketches on which you can use all geometries to place the constraints
