inventor crashes
  • Thread starter Thread starter magrinsi72
magrinsi72
hi a colleague of mine has inventor like me but on his pc every now and then the program gets free and if you did not save it loses everything....
We can't figure out why. .
inventor version? and windows?
update all installed?
graphic card template?
driver updated graphics card?
have you tried to open same file?
with "freeze" do you mean inventor closes? if you ask to send error report?
You have to be a little more specific about the tests carried out so that we can understand what happens.
invemtor 2024
windows 11
rtx3500 ada
31.0.15.5161 driver
It doesn't happen to me... .
The weirdness is, we've changed our whole pc and keeps doing it. . ! ! !
you all new hw and sw.
upgrade reinstalled all....
random....typically he goes away and finds frozen inventor... sometimes it freezes also working
I had a similar experience and the problem was a faulty mouse or a monitor cable to replace, personally I would not exclude them a priori.
Right now, my inventor 2023 has stuck at the opening of a file.
yesterday, on the same file, threw me out 2 times from windows, turned off pc and lost changes.
between the first and second time I worked quietly for hours.
@ Stefanobruno difficult to determine a cause, I had a similar problem in two cases, one was a network problem and the other a hard disk problem and was brand new.
there are then bugs and glitch software, as well as files (parts/assiems) slightly corrupt that can give problems.
always important to install the last patches (check that even on this aspect the two pcs are aligned).
