inventor holes
  • Thread starter Thread starter mauro418415
mauro418415
Excuse me, gentlemen.
I'm back:
I'm a gemetra working between the abruzzo-marche-umbria,
for production work special furniture use inventor and in constantly improving production times I need to decrease as much as possible the drilling times on the inventor.
:bekle: give me some tips please
hello to all and good work.
I'm back:
hello and welcome.
Sorry the question, but it will be 6:00 after a really bad day, but...
Do we have to "react" you? ? ?
inventor has, unlike other types of sw, 4 types of drilling
linear
concentric
on point
by sketch
the rest are details and amenities. . .
What do we have to help you? give us an example, put a picture, describe the problem... .
You know, the forum is not populated by clairvoyant and psychic.
If you go to the mechanic and tell him, "hey, I change often march. What do you think you're gonna give me?
we do not want to be antipathic but mbt is right, you have to be a little more specific in the questions, otherwise it is impossible to answer (except that, if not mistaken, you had asked the same question a few weeks ago and we had responded the same way...).
information that could be useful:
Do holes that pass through multiple pieces to be fixed together?
Are the holes so many, maybe put in series all at the same distance?
do you need to make calculations on the number / size of the holes?
do similar components that only vary in length for example and have a number of holes that varies with the length itself?
Good day to all
you missing information are
that the holes are many, some put in series at the same distance others not,
I need to make calculations because I have the limit to put them to 40 mm from the edge of the piece, the size of the holes has only one size and rarely two, and the quantities of the holes varienao according to the length of the piece.
hello and thanks for the help
Fortunately there is still someone who in Italy gives useful advice:finger:
Good day to all
tried with i-feature?? ?
You can also use the series. if you make a hole on sketch you can make sure that the length of the line in the sketch fits the length of the piece (the quoti at the ends and put a reference fee to know the length)
then make a series by putting as an option "distance" and he modifies the whole so as to fill with n holes the distance you set and that can be referred to that of the sketch
then... bo. do some examples and we'll see.
we are still the example of the "frequent change, sometimes from the 2nd to the 3rd to the 4th. I also happen to jump a march and put on 1st..."
Why? Are there more abroad?? ?
