MauroTC
Hello.
I'm trying to try to flirt with inventor studio to generate a video.
After so many tests and tests I have received with satisfaction to combine, as I wanted, constraints animations, position, transparency effects, camera handling and zomm, etc. in order to generate a sequence of 20 seconds.
but the disappointment (the problem) now lies in the true generation of the video; as much as you change the settings and options that offer quality is very poor. in the rendering phase (which lasts about 40 minutes to generate the 300 frames!), the individual frames can be perfectly seen and everything seems ok.
In fact, instead, reproducing the video, apart from the first frames, which are a static shot, all the following, with the camera zooming and rotating around the machine, have a sharp decay of quality, with showy squares on the surfaces and a poor definition of many contours of the components, sprattutto supoerfici lucide.
In short, a very unpresentable video!
I'm probably wrong with the settings, or is some hw component not up to?
Here, what I would ask is, to whom there is already passed and surely has more experiences than me:
could suggest the optimal settings (there are tens, already only by choosing the wmv or avi format and for the latter a sledge of different compression systems, each of which can be set with certain settings...)
to get a good result?
also because every test counts almost an hour between settings and generations of videos!
(e.g. to give an idea, the 20 seconds of video in wmv format give rise to a file of 1.3 mb.)
thanks in advance. . .
