vale999
I tried a little around but my problem is not dealt with.
I am exporting from inventor a set, redesigned as surfaces not as solid, to use it as ansys model. where I have holes (e.g. bolts) I need to define keypoints, perhaps by dividing the surfaces with cross lines and then filling the holes, so that the ansys mesh creates a knot exactly in the drilling points (recognising the intersection of 2 lines as keypoints).
My problem is to divide the surfaces or draw lines on a surface directly into inventor to avoid doing it in ansys with boolean.
If there is any expert in this field I helped :36_1_4:
thank you in advance and hope to have been clear
