inventor2011 - command foro-filettatura
  • Thread starter Thread starter PRIORE
PRIORE
Good morning to all
I wanted to pose a problem:
I made in a table a partial section, but using the command “hole and thread rate” the automatic definition g1/2 is accepted only if I click on one of the two exteriors or the lines that delimit the hazelnut. :confused:
to quote the outer diameter I must perform the force in manual.
the command instead function perfectly in case of complete section.
someone has suggestions to give me why I don't understand if I'm the one who doesn't know the whole program or we're in the presence of another bug:
allego pdf.
thanks and good day to all
Good morning to all
allego pdf.
hi priore.
I also tried to reproduce a partial section like yours on a cylindrical piece of 1/2" gas diameter and makes me exactly the same joke that you do.
ie on the complete section works perfectly, while when I go to quota the partial section, I can select one edge, the other does not let me select it, as if I clicked in the void.
I think that's how the command is done and that it's not a hole, though if it's done so it's hurt. You don't miss it.
let's see if any other user has any different solutions.
