iportation iges
  • Thread starter Thread starter nino66
nino66
I am trying to import an iges file (created in pro-e) in sw 2010 but I miss a lot of things. I made a test by importing it to rhinoceros (with a demo version) and converts it perfectly and everything!
I don't understand why sw can't. I tried to change every type of option (tolleraze, and the other flags) but the result doesn't change even if I would expect to see something different, if you can't create the solid at least have the surfaces, even if not all! :confused:
Does anyone have any idea of extra options I didn't consider?
thank you for any help.
I'm having trouble in my imports, or you're adding the result you got or redesign it.
Unfortunately, it is not even thinkable because it does not convert me anything, not even a partial, contrary to rhinoceros. Obviously I will look for other roads (e.g. send it back to other formats) but what amazes me and that nothing changes even changing the options.... should at least give me the surfaces even if not perfect!
I often rebuild in rhino.
Indeed, there are tools to fix the surfaces, through which the corrupt surfaces are eliminated that can be recreated.
you must perform import diagnostics under tool menu
wave
