iproperty collection
  • Thread starter Thread starter brovind
brovind
Good morning, I read the info on this topic, does anyone know if the problem of iproperty collection has been solved for win 7 64 bit? I can't make them work while I use them very well on xp pro.
thanks in advance
is not so xp or 7, but x64 the problem
Thank you, I had realized that the problem was on the 64 bit, you know if someone solved ' or found a workaround for the "firstviewscale problem" ?
Thank you in advance.. .
Okay, I've already read all these info, my problem is that I use the inventor's "dwg" on these cartilages I get the problem.
I don't know if it works with the same macros, if you say I try, maybe I ask for help... .
I thought, that if I do not resolve, to temporarily insert a hand editable field in the cartiglio, hoping that the problems of iproerty collection will be resolved. .
I never used inventor dwgs, but I did two tests by setting it as a default model to the rescue (it is right that the standard model file is a .idw anyway? I don't know what I'm asking you) and the scale took me and even opening this dwg in autocad the scale was... Then I don't know if I did everything right because, as I told you, I never used the inventor dwg. Let me know for the default model if you still have it in .idw.
in our templates there are both .idw and dwg models.
default to creating the new file we open a mod. .dwg
practically we idw mods no longer use them avoiding a passage.
We haven't been able to prove yet, as soon as I can tell you...
if you have new info I thank you in advance. . .
