irregular diameters on stl
  • Thread starter Thread starter Antomasi
Antomasi
hi to all, for some time known that the diameters of solids exported to stl become polygons and do not remain circles. Is there any parameter to set to ovviare?
thanks for the vs answer
But wasn't it always? What you could do is increase the number of segments constituting polygons in order to approximate you more to the theoretical circle.
Thanks hunter, until now I never needed to change this parameter, so I wasn't aware of it. However the value to be set is not what you indicated but the right "flat angle surface" I put it to the minimum and it works. still thank you
