Irregular listing profiles
  • Thread starter Thread starter Sandra_ME30
Sandra_ME30
Home 19.12.15 15:41
Good morning
My name is Darius and this is my first topic on this forum. I am a student at the third year of mechanical engineering.
I would like to know or to have some advice on how in nx I could quote an irregular profile. to make me understand better I add an attached image. for problems id display the design is made by broken lines but however as it is intuitive are two circle arches.
thank you in advance for your answers.
I hope dariob read this discussion and rewrites the forum
being registered after 14.12 I am not able to send him a pm.
Sandra
threshing 20.12.15 13:06
originally written by Home view message
Good morning
more or less
should be so
you have to put the interconnects between the various rays
Maybe someone is missing in the sketch
Thank you very much
Home 20.12.15 13:11
Thank you very much.
I just don't think it's okay, because for analytical design problems the profile is not a circle arc but a parable.
I thought of making a quotation just for irregular profiles, so at regular intervals of height I index the thickness. But I think it's hard to do on nx10, isn't it?
threshing 20.12.15 13:25
I don't use the sw
But everything could be done with two normal axes between them
and indicate shocks every tot mm
from them
I think it's not a big prob.
Thank you very much
Good Sunday
baskets1959 21.12.15 11:02
nx share everything you want, just give it the correct references (you can put n-points on the curve and quota them compared to references, for example).
But first you have to understand what the quotation is for. if you have to feed the profile to a laser cut, for example, you don't even have to quote it, if you have to make it to a file modeler you will need n data, if you have to reproduce it to the cad you will need other data again, if you have to make it measure ....
