quattrox
Hello.
You should help me
The question is as follows:
I installed autocad 2009 on the computer but when I tried to put a dwt as layout appeared the writing:
unreversible error :unhandled delayload " ac1st19.dll" module not found exception at 7554812fh
I'll tell you better.
I need to put a cartiglio as layout then I went to the layout / right button / from the model / I selected the file dwt / booooooom got stuck and after the autocad message turns out alone.
help me pleasee! !
You should help me
help me pleasee! !
