is the class of general tolerances parameterized?
  • Thread starter Thread starter MORENO100
MORENO100
Good morning to all,
I have some time and I would like to improve the management of the general tolerances class iso 2768.
I use creo 2.0 and I see that in the properties of the prt models I can set it natively in the menu setting tolerances >>> class tolerances.
my goal would be to set the tolerance class in the above menu and that this setting will automatically change the indication present in the folder of the corresponding drw.
the question is: is it possible to do so?
My hope is that the setting of the class of tolerance set in the properties of the prt models is attributable to a parameter that can be recalled in the drw folder box, but this hypothetical parameter as it is called?
hi moreno try to see if you are useful this doc I attach you is how I create formats
Good day to all,
I intervene because I have exactly the same need.
the table proposed by playmb can also be useful but replicates the table used by creo which is recalled with the command setting tolerances >>> class tolerances indicated by moreno1000.
it would then be completed with the different tolerance values according to the degree of precision selected fine, medium, etc... so that the data indicated in the cardoon change according to the accuracy set.
it would be really useful to know, if it exists, the name of the internal parameters of creo.
grace to all.
Michael
