DB-TUNING
Hello, Raf! !
I see you're still struggling with your brick problem...(if you used the lego maybe it was + easy...ihih... I'm kidding of course! )
In my opinion, as I said long ago the big problem is the management of such projects. if you are the only one who manages work with inv and without office support for ideas, tricks, tips etc. to solve the various problems you will encounter from time to time, it will be difficult to succeed in bringing to conclusion the work in decent times, always if then you will not be stuck on + beautiful or as told by others here on the forum, if the workstation at your disposal will manage everything.
You should put yourself there and start doing some evidence, but this may mean "push" a lot of hours....depends if it suits you! at the end once everything is realized with inv, what benefits would you have? and for future similar jobs would you be able to recover the old project or do you have to start up everything from scratch? In my opinion, you have to answer these questions before starting work to assess whether or not you should use the 3d.
