Good morning Waltzmaloobocon , first of all thanks for the answer, the variable is set in this way: view_note std_isoI use an old version but to change what you look for in the dtl looks at the view_note variable and set it on std_iso
excuses not sections but auxiliary viewsGood morning Waltzmaloobocon , first of all thanks for the answer, the variable is set in this way: view_note std_iso
but besides this variable does not exist something specific? for example for the sections I have this:
aux_view_note_format view %viewname-%viewname
Thank you very much, while I look into the file you sent me, if someone else should know the solution let me know, I'd be grateful!Bye.
Config options for creo 9 design should be these.
I want to see:but just to understand. .
What would you want it to be written?
I've got it
view_note std_ansi
default_detail_view_name_style letter
and I'll be
detail to
10:1 scale
instead of letter you can put roman and you will appear Roman numerals. .
perfect, exactly what I wanted!but just to understand. .
I've got it
view_note std_ansi
and I'll be
detail to
10:1 scale
Thanks again for the hand! of course thanks to all of you for suggestions.No.perfect, exactly what I wanted!
View attachment 67942Thanks again for the hand! of course thanks to all of you for suggestions.
