isoparameterize two part in the product
  • Thread starter Thread starter iron72
iron72
Hello.
I was trying to bind two details within the product so that if for example I change the first detail the second follows the size of the first.
I'm just drowning.
thank you for any advice.
Now I am trying to tie two sketches of the two details in the product, but also this seems without desired effect.
I can help you but I don't understand the problem well; I use 2 systems, the first is to create the sketches of the 2 details on a catpart and bind the sketches in the desired way, then using these I create the 2 details in the product (skeletal style of proengineer), the second is using the equivalent relationships or quotas. usually avoided to bind 2 details. You should better explain what you want to do.. .
What I mean for example if I build a tree and a particular with a hole, and assemble them, I would like that if I change the diameter of the hole, also the diameter of the tree is changed directly proportionally.
I would like the geometry of the hole to be linked to the geometry of the tree in the product.
what can be achieved by modeling it in contextual mode.
for this you must activate the option "maintain connected with the selected object" in tools\options\infrastructure\part infrastructure "general table".
it seems to me that this is the classic case to use the knowledge module with its formulas.
Mar
