it doesn't show me the 3d
  • Thread starter Thread starter Lau ra
Lau ra
hi use archicad 10, if from the camera I show everything in the 3d I don't see anything, if I start the render it makes me see everything correctly, if I select I see the selectionView attachment 378. grazie!
is a video display problem. depends on the pc (graphic card) and the display engine you use. go to 3d settings - there should be opengl engines and internal motor - which are you using?
Staff online
