join restraints
  • Thread starter Thread starter s48ry
s48ry
Hello.
I am new to the forum and I hope you can help me:
I wanted to know if there is a command (I use autocad 2008) to be able to combine different restraints into one. .
Thank you in advance.
Hello and welcome.
I invite you to present yourself in the appropriate discussion in the area.
regarding your problem.. .
I think the only solution is to remake the restraint
at the limit you can try to "extend" it to the new borders.
with autocad in fact it is not possible, perhaps with some plugins, but at the moment I do not turn out plugins that allow the union of restraints.
Why do you need to join them?
I imagine, if you allow me the suppository, that has more fields of adjacent areas in one piece and want to join them in order to change them all together.
In fact.. mainly for this reason
the second: being material of an examination I wanted to make it as ordered as possible. .
regarding the selection of all can resort to the selerapid command, then depends how these restraints are organized, if by color, layer... etc.
in this way you can change them in color block, type of restraint, etc.
for the union at the moment I do not see solution. . .
If then the problem is to net in one shot only a complex design, I recommend you to freeze all unnecessary layers that you do not need for the creation of the dashboard (I hope you have divided the design on multiple levels) to facilitate and speed up the processing of contours
