Gioan
Hey, guys.
I wanted to take advantage of it to ask for advice,
I have to joint two shafts diameter 60 full from 2000mm each with a threaded bar m30 l=50mm (see sketch attached).
the tree will be subject exclusively to bending ( negligible cutting).
I performed the calculation of the max sigma considering as a resistance module the threaded bar core section and the maximum mf (f/2x2000).
now I have two dubb
i:
1) leaving considerations between ductile and fragile materials (in my case, therefore, in fact, the problem would not arise) according to you should be considered a factor of concentration of tensions (usually considered for sectional variations within the same piece, but in this case that are distinct pieces should however be considered? )
2) the length of the mothervite has influence on the seal of the threads and this is obvious, but according to you it is correct to use the axial force that prompts each of the two screws equal to the max sigma (first calculated) multiplied by the hazelnut section of the threaded bar? (in my opinion it should be a precautionary calculation since I do not consider the trend to "failure" due to the bending).
Thank you for your opinions.
now I have two dubb
