key notes
  • Thread starter Thread starter Andrea Dian
Andrea Dian
good evening, it is not long since I use revit 2013 after drawing the plan of a plant, I am trying to imagine it for the presentation in the best ways.
after entering the key note for some objects, I created a key notes legend.
In addition to the key value and the key note text, in the abacus of the legend I would like to insert also the parameter "dimesion" and then add a new column inside the abacus and consequently in the graphic table of the legend inserted in the table.
to do this I have selected the family m_ label note key, executed family modification, once I opened this I clicked on create, text label, clicking on label text, opened the window edit text label where I would just enter a new parameter category "dimension" but I don't know how to do as the new parameter function is not enabled.
Thank you for your help.
:finger::rolleyes:
not possible. only these two parameters are possible in this case. for what do you want another parameter?
I would like another parameter so as to make a legend where I also have the size of each chord, accessory etc.
I tried to solve by doing the abacus of pipe fittings, but by doing so it does not give me the list of every single fitting or accessory for tubing inserted only once, but many. for ex if I insert 5 curves, three crosses and two valves for pvc pipe, I would like you to give me a legend with every single element repeated once only, not n times how many it was inserted in the project.
Also it is possible to print or create a list of sheets/cards, or a summary in which I also put the detailed drawing with quotas and descriptions of each piece... ?
thanks and good day.
I solved the problem in the sorting window /grouping in the details of the created abaco by removing the check on "elecate every instance" :) :)
thanks the same, if you have other ideas to make legend or suggestions are here to "absorb" knowledge revit :d
Good day to all
