keyboard commands no longer work
  • Thread starter Thread starter Dexster
Dexster
Argh, as the object doesn't work for me anymore.
like the h for holes and it and to extrude by means. I don't even get a keyboard command. . .
use inventor 2012
Maybe I disabled something but I don't know where to enable it. . .
Dexter
I did 3 versions with this problem and I didn't jump out... the "problem" is only closing the search bar at the top right on the title bar... If you are looking in the forum should ease us just a diacussion about it.. .
Try... if you leave the commands open, if you close it they don't flee anymore. Don't ask me why!
Then I don't know. is it not that you want to use a command not assigned or assigned to anything? Did you check the shortcut settings?
Then what I did now. .
I restored the basic configurations but to say the letter and that in the office I do not know why it is assigned to the extrusion at home it does not work.
I checked in
? in the drop-down menu I went to quick reference alias/ shortcut keys
I did a nice restore
(I'm sure I didn't set a blessed bat because as I have it in my office I have it at home)
I went to the keyboard board and made a reset all the keys
to tell you a ctr-p for printing works and for extrusion no
I went to see if the command is managed and is not assigned to any short alias ok well the check but I can not assign it are 2 the commands that I have to assign h and but I am thinking also to take the configurations in the office and import it because other solutions I do not see or find.. .
Dexter
the strange thing is that it stopped working definitely from a nice touch of time and vabbhé not that never happened to me it never mattered today instead I noticed because it is a little na ball go to take the command hole or extrude that are the most used commands... what in the office I never do...
use inventor 2012
Dexter
I solved by resetting the keyboard aliases I clicked everything left in customization where I inserted the keyboard alias cacchio to have understood it before it was better, sure I became mad x nothing "_____" but a glass of wine has solved everything :d
Dexter
