keyboard commands not active in autocad 2013
  • Thread starter Thread starter L'Inventore
but didn't you even install express tools? Enough, I surrender
Not what it is. If that's what can solve my problem please tell me where to find it and make it attvo, and at least I know that you owe you rivers of beer!!
I solved the problem by overwriting the pgp file with that of the previous version. I don't know if it's a proper operation, because it's working now!
I apologize for my insistence on help and thank you all.
I lost this discussion. . .
2013 Italian mechanical suffers from this problem... every time I reinstall I have to resume the old .pgp to get back the Italian aliases. . .
I thought you were the only one who had this problem!
However those of the autodesk to every new version instead of improving according to me worsen:frown:
giga you who are moderator is not better than to move this discussion in autocad mechanical, since autocad is not affected by this problem?
I would have seen her before... and since I knew the problem since 2013 maybe the solution came first.. .
I hope it is from warning to post, in the future, in the most consonable forums.. .
I will ask moderators to move it to the right place (I cannot "take" a discussion from another sub-forum)
I'm sorry to ask for the piff, but I also suffer from this problem. in the office, however, I only have pds 2013 installed, I would have the dvds of 2012 and 2011, but in that jungle I do not know where to find the correct pgp file.
Could some good soul send it to me, please? or could you tell me where to find the correct one in the dvds of pds 2012?
I saw that in acad "liscio" the problem is not there, it's just mechanical.
Thank you very much
s....I would have the dvds of 2012 and 2011, but in that jungle I do not know where to find the correct pgp file. . .
pure autocad in pgp file header reports:
; autocad program parameters file 2012
; definitions of external commands and relative aliases
see if in yours someone with the word of mechanical
Thank you, I look at each other.
This observation put me on the right track to understand why this strange "behaviour":
autocad "liscio" loads the acad.pgp file in the directory c:\utenti\username\app data\roaming\autodesk\ecc. etc.\ita\support\ (in win7, on xp is under documents and settings), which correctly reports the commands localized in Italian, e.g.:
l, *line
etc.
while the mechanical loads the acad.pgp file in c:\programs\autodesk\autocad 2013\acadm\it-it\, which has the commands in English (baco in the language pack?), type:
l, *line
etc.
in fact if by keyboard you write _l the alias works correctly (it is as if you write _line).
solution: copy the acad.pgp file that stands in \utenti\... in the \programs\... removing or renaming the other.
I hope that this will help someone save a couple of ... improperly:wink:
l, *line
etc.
l, *line
etc.
Thank you very much! this solution should be put on the front page, I finally stopped having to enter _ before the various commands.
Good morning, I read all the discussion by checking in the autocad installed on my pc if there were any differences, but nothing.
then: I installed autocad 2015 (German version) and express tolls, in the acad.pgp file the commands are inserted correctly, as well as in the aliasedit, but when I go to type on (stutzen - size) it makes me start the search command (suchen), while to start the command size I have to type tr (trim), this joke does it to me since I installed the English tolls What if I change the language?? I don't know if I've explained I thank you so far
hello to all, I realize to exhume an old discussion and especially for a problem slightly different from that in question. I normally consult the forums and 99% of the time I solve the problem without disturbing anyone, because I find old discussions but this time I have not found answers.
the problem is that at the moment autocad, version 2014 that always worked well, does not allow me to select and give a command, but only to give a command and then select, both from keyboard, and from icons.. I find it very uncomfortable because I am accustomed to reasoning on the contrary. Is there any variables to change? something I have inadvertently changed to restore?
Thank you all!
Hello, Tristan, mythical!
I imagined it was stupid:)
Thank you for answering me in a flash!
